Hey bond007
I have a few questions about your issue.
In your screenshot you have two fields, one called "Category" and "Sub Category".
How did you add them to the form? I presume, that they are just 2 added field in a custom form with the type "Choices", correct?
And if I understand you correctly your idea is to add ONE custom form field of type "Choices", put in a few choices in the form of "A", "B", "A / C", "B / C" (a.s.o.) and this should generate 2 dropdowns as we have now in the "Help Topic" section.
Frist one with options A and B
Second with options C and D (a.s.o.)
Everything right to this point?Suntas, I am sorry for delayed response. Was busy with some work here.But you got it right, If we could add this to ticket entry form page.
