Hello,I have a simple Ticket Filter:When "Ticket / Issue Details" CONTAINS my name, the ticket should be assigned to me.Unfortunately this filter does not work, when my name is mentioned in the "Internal Note" of the existing ticket.If I remember well, this worked with earlier osTicket versions.Is there a possibility to make such filter work? I could not see "Rule matching criteria" for "Ticket / Internal Note".Can I add a simple patch to the code?Thank you,Augustas
