I am referring to a thread in the 1.7 section of this forum. I tried various versions from 1.7.4 up to the preview 1.8.1 and always have trouble connecting to my SMTP server. I am running osTicket on a hosted Apache Server with php 5.4 (also tried 5.5).When trying to configure an email address to send via SMTP on my own mailserver I ran into this error message: Failed to connect to smtp.mydomain.tld First thing I did was double check credentials of course, but they are fine as I can receive via pop or imap without issues. So I suspected the settings on my mailserver to be somehow in conflict. To verify I tried to use a different email account from 1&1 and get the same error message. Therefore I am pretty sure that there is a problem with how osTicket talks to the SMTP server. There is a note from 1&1 saying that smtp needs to have authentication but NOT Secure Password Authentication (SPA) - is that maybe the issue here?I veryfied also the correct ports etc. with other email clients the connection is working without issues, so it has to have something to do with osTicket - or did I miss some vital adjustment or setting?Help is much appreciated, this is the very last thing I simply cannot get to work. PSI also tried connecting without SSL (with appropriate ports of course) but the result is the same.
