The owner of the server isn't accurate on what '@' does - it is solely error message suppresion, the error still occurs it just isn't reported. For the 'webpage' to show there has to be HTML, which is what the php code is supposed to be doing - generating the HTML to create the control panel in the browser. If you right click in the browser window and hit 'view source' and don't see anything then it's highly likely the PHP code failed and therefore failed to generate the needed HTML. Which gets you back to this question - what were the error messages you got before you added '@' to those lines?
David
i went and removed the "@" on all the lines i set
what i get on the main page where it says "Support Ticket System Offline"
Warning: ini_set() has been disabled for security reasons in /www/zxq.net/i/m/p/imperialism/htdocs/support2/main.inc.php on line 31
Warning: ini_set() has been disabled for security reasons in /www/zxq.net/i/m/p/imperialism/htdocs/support2/main.inc.php on line 32
Warning: ini_set() has been disabled for security reasons in /www/zxq.net/i/m/p/imperialism/htdocs/support2/main.inc.php on line 35
Warning: ini_set() has been disabled for security reasons in /www/zxq.net/i/m/p/imperialism/htdocs/support2/main.inc.php on line 37
Warning: ini_set() has been disabled for security reasons in /www/zxq.net/i/m/p/imperialism/htdocs/support2/main.inc.php on line 44
Warning: ini_set() has been disabled for security reasons in /www/zxq.net/i/m/p/imperialism/htdocs/support2/main.inc.php on line 45
Warning: session_start() : Cannot send session cache limiter - headers already sent (output started at /www/zxq.net/i/m/p/imperialism/htdocs/support2/main.inc.php) in /www/zxq.net/i/m/p/imperialism/htdocs/support2/main.inc.php on line 48
Warning: ini_set() has been disabled for security reasons in /www/zxq.net/i/m/p/imperialism/htdocs/support2/main.inc.php on line 87
what i get for the admin login is this
after admin login i get this
Warning: session_regenerate_id() : Cannot regenerate session id - headers already sent in /www/zxq.net/i/m/p/imperialism/htdocs/support2/scp/login.php on line 52
and on the control panel i get this
Warning: require_once(Mail/mimeDecode.php) : failed to open stream: No such file or directory in /www/zxq.net/i/m/p/imperialism/htdocs/support2/include/class.mailparse.php on line 19
Fatal error: require_once() : Failed opening required 'Mail/mimeDecode.php' (include_path='.:/usr/lib/php') in /www/zxq.net/i/m/p/imperialism/htdocs/support2/include/class.mailparse.php on line 19
