i WAS WONDERING IF ANYONE COULD HELP ME OUT WITH A PROBLEM I HAVE NOT BEEN ABLE TO FIGURE IT OUT... I HAVE HAD THE PROBLEM SINCE I HAD INSTALLED OSTICKET 1.6 STABLE BACK IN FEBRUARY OF 2010
AFTER I HAD DID THE UPGRADE ON THE MAIN PAGE ON THE RIGHT SIDE WERE IS ALLOWS YOU TO ENTER TICKET # AND BELOW THAT WHERE THE BUTTON IS THAT U CLICK TO CHECK STATUS IS OFF CENTER IT SHOULD BE DIRECTLY BELLOW WERE YOU ENTER YOUR EMAIL ADDRESS
SO IF ANYONE CAN TAKE A LOOK AT IT AND TAKE A LOOK AT THE SOURCE CODE TO EXPLAIN TO ME ON HOW TO FIX THIS PROBLEM I KEEP RESEARCHING THE CODE AND I CANT SEE A PROBLEM AND WHY IT WOULD BE PUSING THESE FIELDS TO THE LEFT...
HERES MY WEBSITE TO TAKE A LOOK AT IT JAYSONBERGER.COM/SUPPORT
