EDIT - Haha. Thanks a lot for the help. I was being an idiot and looking in the PHP.ini documentation at the top of the file and not the actual switch. Thanks a bunch!
EDIT #2 - Now it is looking correct, but when I put all the information in and click "install" It goes to a blank web page and nothing happens.... Sorry to be such a bother.
Edit #3 - Well, looks like I accidentally installed MSSQL and not MySQL support when I installed PHP! So that was my bad. :-/
Now, however, I am getting an invalid SQL syntax error when I try to install. I am using the SQL server root login. I will enable error logging and let you know what that turns up.
Edit #4 - Wooo. Got that issue worked out too! Sorry about the running blog here. Here is how I solved it:
http://www.osticket.com/forums/showthread.php?t=199(http://www.osticket.com/forums/showthread.php?t=199)
Thanks so much for the forums, guys!
