Background:
Host: Hostgator.com
Using cPanel
I've installed osTicket and finally got the email piping to work using SMTP. I had to correct line 87 in pipe.php to add a semi-colon to the end (thanks ScootyDoo).
Everytime I turn on Autoresponders, I end up in a loop and have to disable them. I think it has to do with how I've configured my settings since I don't fully understand what each of the emails should be doing.
Under Admin Panel -> Settings -> Preferences...
Under Email Settings:
Incoming Emails, I've checked Enable email piping
Outgoing Emails, I've selected None: Use PHP mail function
Default System Email is set to support@domain.com
Default Alert Email is set to newticket@domain.com
System Admin Email Address is set to newticket@domain.com
Under Autoresponders (Global Setting):
New Ticket = enabled
New Message = enabled
Overlimit notice = disabled
Under Alerts & Notices:
New Ticket Alert = when I set to enable and check either admin email or department manager is when I get the loop. As soon as I disable, I don't get any notification. So I assume that I have an email preference setting problem somewhere that is causing the loop but can't find the root cause.
New Message Alert = disabled
New Internal Note Alert = disabled
Overdue Ticket Alert = disabled
Under Admin Panel -> Emails, I have three email addresses I've created.
For affiliates@domain.com and support@domain.com, under Email Info, Auto Response I have NOT checked Disable autoresponse for this email so it is enabled. I've filled in the Login info and smtp settings. However, I don't have the mail account filled in. Could this be the issue? Is it needed for SMTP or email piping?
For newticket@domain.com, under Email Info, Auto Response, I have checked Disable autoresponse for this email so it is disabled. I've filled in the Login info and smtp settings. However, I don't have the mail account filled in. Again, could this be the issue? Is it needed for SMTP or email piping?
Under Admin Panel -> Departments, I have two departments I've created.
For both Affiliates (dept email is affiliates@domain.com) and Support (Dept email is support@domain.com), I have the autoresponders set as follows:
New Ticket = enable
Auto Response email = NewTicket@domain.com, could this be part of the problem?
As you can see, I don't fully understand how the autoresponders work with the departments, emails and global settings. If someone can point me in the right direction, I'd greatly appreciate the help.
Thanks!
Hokkaido
