Hi everyone
I'm getting the error message: Invalid SQL schema. Get help from Developers when I first try to install Osticket. I had this installed before so I'm not sure what is up. The other links such as:
http://osticket.com/forums/showthread.php?t=312&highlight=Invalid+SQL+schema.+Developers(http://osticket.com/forums/showthread.php?t=312&highlight=Invalid+SQL+schema.+Developers)
Do not seem to apply as the .sql file does not have that reference mentioned.
Running the following:
Windows XP Professional
PHP Version 5.3.0
MySql Server version: 5.1.37
OSTicket 1.6 RC5
Any ideas?
Thanks,
Robert
