Problem#1:
If I reply or if a ticket is created - I/or my customers do not get email messages any longer.
Problem#2:
If I create a ticket in the Staff portal I get the following error after I type in the email address of the user. I get AJAX error: 406
Problem#3 (Even though the ticket shows up in osTicket)
This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of its recipients. This is a permanent error. The following address(es) failed:
pipe to |/home/jeroth/public_html/api/pipe.php
generated by support@jerothhosting.com
The following text was generated during the delivery attempt:
------ pipe to |/home/jeroth/public_html/api/pipe.php
generated by support@jerothhosting.com ------
No log handling enabled - turning on stderr logging read_config_store open failure on /var/net-snmp/snmpapp.conf read_config_store open failure on /var/net-snmp/snmpapp.conf read_config_store open failure on /var/net-snmp/snmpapp.conf
