Hey There,
I have successfully installed the osticket package on linux server..and i am using support@domainname.com mail for support and this e-mail is created with Google Apps, as we are using google apps for our e-mail.
now when i open ticket and fill form.. after successfully finishing the form replies that the e-mail has been sent with ticket no. to your account.. but no e-mail has been sent to that e-mail.
i have made POP3 Setting (Optional)
POP3 Status: Enable
POP3 Host: pop.gmail.com
POP3 User: support@domainname.com
i have checked Enable Auto Cron..
and in Email Settings > Mail Methods: i have checked Enable POP3 email fetch..
can u please help me out..
or is there any other configuration that i have missed.. i have not made any changes in any file..
Thanks,
Yash Bansal..
2 months later
am also in same prob ... Invalid login
but login and all correct
5 days later
i have a problem with email to
Invalid login
Can someone help us with those prblems?
8 months later
Same issue here....
Any one with a solution yet? Is this just a gmail issue or a google enterprise apps issue?
I just tried this with my email being hosted at Google (gmail) and I get the same problem with RC5....? :
Firewalls and SMTP
ybansal82: Check to make sure you are specifying a SMTP server on your default mail server, or the e-mail address being used for email.
chanhope: Can't offer much suggestions on this error - connection refused may be a firewall issue. Talk to your webhost/systems administrator.
darkside: Same advice as above - most likely a firewall issue
geost: can you be more specific about the problem you are having?
Generally speaking, make sure that php-mcrypt is installed otherwise your usernames and passwords won't be saved right.
5 days later
i have (Invalid login. Check POP settings) Message
Dear Sir;
Good day, kindly be informed that I'm interest to install osTicket.
the process is runnig good, but with Email setup it is NOT !
after i configure my pop3 mail, i found this message.
Can't open mailbox {mail.XXXXX.com/pop3/novalidate-cert}INBOX: invalid remote specification
also this message appear in the osTicket System Logs
Wed, Jul 15 2009 4 mcrypt missing
Cryptography extension mcrypt is not enabled or installed. IMAP/POP passwords are being stored as plain text in database. 127.0.0.1
I'm sure from my settings is right.
I'm Using ...
OS : Windows 2003 Server.
Apache Web Server Version 2.2.4
PHP Script Language Version 5.2.1
MySQL Database Version 5.0.27
osticket_1.6.rc5.tar.gz
Please would you Support me, and thanks in advance for your time.
Regards...
Ahmed Abdelaziz
ahmed.adbelaziz:
It would seem that your logs are pointing you towards your problem. Did you verify that mcrypt is installed on your server? If not install mcrypt as a starting point.
extension=php_mcrypt.dll
Thanks for your kind response.
concerning to mcrypt, i remove the ( ; ) before this line extension=php_mcrypt.dll
in php.ini file which locate in my windows directory;
so would you have another suggestions?
Regards...
Ahmed Abdelaziz
Just to be sure, you have the php_mcrypt.dll in your extension folder right?
New Error ( SMTP Error )
Thanks Dear for your interest;
i solve IMAP Problem with - copy file libmcrypt.dll to windows\system32
Now i have new problem that appear ( SMTP Error ) in System Logs osTicket.
so would you have any idea
7 days later
Hi there,
I've hit this error too, it seems to be due to trying to connect to a non-ssl account but supplying the novalidate-cert option, which is an ssl only option.
I'm not 100% sure this is the right fix, but it seems to work:
In class.mailfetch.php, around line 51, remove /novalidate-cert from the string, the line should now look like:
$this->serverstr.='}INBOX'; // add other flags here as needed
Add it to line 49, which should now look like:
$this->serverstr.='/ssl/novalidate-cert';
Hope this helps.
5 months later
fix for php-5.2+ pop 110 invalid remote specification
Just for the record and confirmation. Thanks Mace!
Removing the above /novalidate-cert does fix the issue.
But do renew the browser windows after applying!
Seems its a bug also related to PHP 5.2+, as you have to go through about 4 pages with hits to find this one applicable for OSticket.
(and it has 0 to to with mycript not being enabled as php module option.)
No worries, happy to help.
It's not specifically a bug in PHP as such, just an API nuance - one that should probably be promoted to the web gui somehow.
Cheers,
Miah
a year later
not working for me
I was facing the issue of emails not been fetched with mcrypt error only in system logs of ost. I enabled mcrypt in php.ini but the mcrypt error is still coming up.
then i did the changes suggested in class.fetchmail.php and i get the following error in email setup:
Certificate failure for mail.chrisons.com: Self-signed certificate or untrusted authority: CN=cexch
SSL is not selected for in email setup.
can anyone help?
solved
can anyone help?
i reverted the changes suggested. the problem was with a custom field in the db which was set to required (not null) so the fetchmail function could not insert data to this field it appeared that emailfetching was not working
19 days later
The mcrypt missing error
I am getting this error too.
mcrypt missing.Cryptography extension mcrypt is not enabled or installed. IMAP/POP passwords are being stored as plain text in database.
can someone help me out troubleshoot the error?
I will be more than glad.
It's exactly what it says... mcrypt is missing and passwords are being stored in the database as plain text.
The system will still work fine, but your mail account passwords won't be encrypted. For encryption to work, PHP must be configured with mcrypt: http://us2.php.net/manual/en/mcrypt.setup.php(http://us2.php.net/manual/en/mcrypt.setup.php)
