It took a bit of time to get this done, sorry for the delay. Adding the dump sql actually made the Que look very messy, as the dump goes to stdout and messes up the queue view heavily. I'm not sure which part of the sql dump you would need, so I went copy pasting from top of page to bottom all the pieces of sql dump I found. I also made dumps of the entire html page as it appeared in case we need it. Can't upload that however. Below are the sql dumps as I copy pasted from the screen. Hope it makes any sense.
`SQL Dump without the FW filter
string(91) "SELECT COUNT() FROM (SELECT A1.id FROM ost_config A1 WHERE A1.namespace = 'core') __" string(62) "SELECT A1. FROM ost_config A1 WHERE A1.namespace = 'core'" string(131) "SELECT A1., A1.session_expire < NOW() AS is_expired FROM ost_session A1 WHERE A1.session_id = 'o1neu0kdhej58ucf0eq6n4k37g'" string(77) "SELECT A1. FROM ost_queue_sort A1 WHERE A1.id = 6 ORDER BY A1.name ASC" string(55) "SELECT A1.* FROM ost_plugin A1 ORDER BY A1.name ASC" string(73) "SELECT A1.* FROM ost_plugin A1 WHERE A1.id = 5 ORDER BY A1.name ASC" string(73) "SELECT A1.* FROM ost_plugin A1 WHERE A1.id = 7 ORDER BY A1.name ASC" string(73) "SELECT A1.* FROM ost_plugin A1 WHERE A1.id = 4 ORDER BY A1.name ASC" string(113) "SELECT A1.* FROM ost_plugin_instance A1 WHERE A1.plugin_id = 5 AND A1.flags & 1 != 0 ORDER BY A1.name ASC" string(73) "SELECT A1.* FROM ost_plugin A1 WHERE A1.id = 5 ORDER BY A1.name ASC" string(107) "SELECT COUNT() FROM (SELECT A1.id FROM ost_config A1 WHERE A1.namespace = 'plugin.5.instance.24') __" string(78) "SELECT A1. FROM ost_config A1 WHERE A1.namespace = 'plugin.5.instance.24'" string(113) "SELECT A1.* FROM ost_plugin_instance A1 WHERE A1.plugin_id = 7 AND A1.flags & 1 != 0 ORDER BY A1.name ASC" string(73) "SELECT A1.* FROM ost_plugin A1 WHERE A1.id = 7 ORDER BY A1.name ASC" string(107) "SELECT COUNT() FROM (SELECT A1.id FROM ost_config A1 WHERE A1.namespace = 'plugin.7.instance.26') __" string(78) "SELECT A1. FROM ost_config A1 WHERE A1.namespace = 'plugin.7.instance.26'" string(113) "SELECT A1.* FROM ost_plugin_instance A1 WHERE A1.plugin_id = 4 AND A1.flags & 1 != 0 ORDER BY A1.name ASC" string(73) "SELECT A1.* FROM ost_plugin A1 WHERE A1.id = 4 ORDER BY A1.name ASC" string(107) "SELECT COUNT() FROM (SELECT A1.id FROM ost_config A1 WHERE A1.namespace = 'plugin.4.instance.23') __" string(78) "SELECT A1. FROM ost_config A1 WHERE A1.namespace = 'plugin.4.instance.23'" string(98) "SELECT COUNT() FROM (SELECT A1.id FROM ost_config A1 WHERE A1.namespace = 'mysqlsearch') __" string(69) "SELECT A1. FROM ost_config A1 WHERE A1.namespace = 'mysqlsearch'" string(61) "SELECT A1.* FROM ost_staff A1 WHERE A1.username = 'HansA'" string(95) "SELECT COUNT() FROM (SELECT A1.id FROM ost_config A1 WHERE A1.namespace = 'staff.57') __" string(66) "SELECT A1. FROM ost_config A1 WHERE A1.namespace = 'staff.57'" string(760) "SELECT A1.id, A1.parent_id, A1.columns_id, A1.sort_id, A1.flags, A1.staff_id, A1.sort, A1.title, A1.config, A1.filter, A1.root, A1.path, A1.created, A1.updated, CASE WHEN A1.sort = 0 THEN 999 ELSE A1.sort END AS _sort, A2.id, A2.parent_id, A2.columns_id, A2.sort_id, A2.flags, A2.staff_id, A2.sort, A2.title, A2.config, A2.filter, A2.root, A2.path, A2.created, A2.updated, A3.id, A3.root, A3.name, A3.columns, A3.updated FROM ost_queue A1 LEFT JOIN ost_queue A2 ON (A1.parent_id = A2.id) LEFT JOIN ost_queue_sort A3 ON (A1.sort_id = A3.id) WHERE (A1.flags & 2 != 0 OR A1.staff_id = 57) AND NOT A1.flags & 4 != 0 ORDER BY A1.parent_id ASC, _sort ASC, A1.title ASC" string(605) "SELECT A1.id, A1.parent_id, A1.columns_id, A1.sort_id, A1.flags, A1.staff_id, A1.sort, A1.title, A1.config, A1.filter, A1.root, A1.path, A1.created, A1.updated, A2.id, A2.parent_id, A2.columns_id, A2.sort_id, A2.flags, A2.staff_id, A2.sort, A2.title, A2.config, A2.filter, A2.root, A2.path, A2.created, A2.updated, A3.id, A3.root, A3.name, A3.columns, A3.updated FROM ost_queue A1 LEFT JOIN ost_queue A2 ON (A1.parent_id = A2.id) LEFT JOIN ost_queue_sort A3 ON (A1.sort_id = A3.id) WHERE A1.id = '83' ORDER BY A1.sort ASC" string(86) "SELECT A1.* FROM ost_queue_config A1 WHERE A1.queue_id = 83 AND A1.staff_id = 57" string(48) "SELECT A1.* FROM ost_role A1 WHERE A1.id = 1" string(76) "SELECT A1.* FROM ost_form A1 WHERE A1.type = 'T' ORDER BY A1.title ASC" string(72) "SELECT A1.* FROM ost_form A1 WHERE A1.id = 2 ORDER BY A1.title ASC" string(391) "SELECT A1.id, A1.form_id, A1.flags, A1.type, A1.label, A1.name, A1.configuration, A1.sort, A1.hint, A1.created, A1.updated, A2.id, A2.pid, A2.type, A2.flags, A2.title, A2.instructions, A2.name, A2.notes, A2.created, A2.updated FROM ost_form_field A1 LEFT JOIN ost_form A2 ON (A1.form_id = A2.id) WHERE A1.form_id = 2 ORDER BY A1.sort ASC" string(53) "SELECT A1.* FROM ost_list A1 ORDER BY A1.name ASC" string(88) "SELECT A1.* FROM ost_translation A1 WHERE A1.lang = 'en_US' AND A1.type = 'phrase'" string(338) "SELECT A1.entry_id, A1.field_id, A1.value, A1.value_id, A2.id, A2.form_id, A2.flags, A2.type, A2.label, A2.name, A2.configuration, A2.sort, A2.hint, A2.created, A2.updated FROM ost_form_entry_values A1 JOIN ost_form_field A2 ON (A1.field_id = A2.id) WHERE A1.entry_id IS NULL ORDER BY A2.sort ASC" string(390) "SELECT A1.id, A1.form_id, A1.flags, A1.type, A1.label, A1.name, A1.configuration, A1.sort, A1.hint, A1.created, A1.updated, A2.id, A2.pid, A2.type, A2.flags, A2.title, A2.instructions, A2.name, A2.notes, A2.created, A2.updated FROM ost_form_field A1 LEFT JOIN ost_form A2 ON (A1.form_id = A2.id) WHERE A2.type = 'G' ORDER BY A1.sort ASC" string(76) "SELECT A1.* FROM ost_form A1 WHERE A1.type = 'U' ORDER BY A1.title ASC" string(391) "SELECT A1.id, A1.form_id, A1.flags, A1.type, A1.label, A1.name, A1.configuration, A1.sort, A1.hint, A1.created, A1.updated, A2.id, A2.pid, A2.type, A2.flags, A2.title, A2.instructions, A2.name, A2.notes, A2.created, A2.updated FROM ost_form_field A1 LEFT JOIN ost_form A2 ON (A1.form_id = A2.id) WHERE A1.form_id = 1 ORDER BY A1.sort ASC" string(76) "SELECT A1.* FROM ost_form A1 WHERE A1.type = 'O' ORDER BY A1.title ASC" string(391) "SELECT A1.id, A1.form_id, A1.flags, A1.type, A1.label, A1.name, A1.configuration, A1.sort, A1.hint, A1.created, A1.updated, A2.id, A2.pid, A2.type, A2.flags, A2.title, A2.instructions, A2.name, A2.notes, A2.created, A2.updated FROM ost_form_field A1 LEFT JOIN ost_form A2 ON (A1.form_id = A2.id) WHERE A1.form_id = 4 ORDER BY A1.sort ASC" string(391) "SELECT A1.queue_id, A1.column_id, A1.staff_id, A1.bits, A1.sort, A1.heading, A1.width, A2.id, A2.flags, A2.name, A2.primary, A2.secondary, A2.filter, A2.truncate, A2.annotations, A2.conditions, A2.extra FROM ost_queue_columns A1 JOIN ost_queue_column A2 ON (A1.column_id = A2.id) WHERE A1.queue_id = 83 AND A1.staff_id = 0 ORDER BY A1.sort ASC" string(79) "SELECT A1.* FROM ost_queue_column A1 WHERE A1.id = 1 ORDER BY A1.name ASC" string(79) "SELECT A1.* FROM ost_queue_column A1 WHERE A1.id = 2 ORDER BY A1.name ASC" string(80) "SELECT A1.* FROM ost_queue_column A1 WHERE A1.id = 16 ORDER BY A1.name ASC" string(79) "SELECT A1.* FROM ost_queue_column A1 WHERE A1.id = 3 ORDER BY A1.name ASC" string(79) "SELECT A1.* FROM ost_queue_column A1 WHERE A1.id = 5 ORDER BY A1.name ASC" string(80) "SELECT A1.* FROM ost_queue_column A1 WHERE A1.id = 39 ORDER BY A1.name ASC" string(80) "SELECT A1.* FROM ost_queue_column A1 WHERE A1.id = 40 ORDER BY A1.name ASC"
string(708) "SELECT A1.team_id, A1.staff_id, A1.flags, A2.staff_id, A2.dept_id, A2.role_id, A2.username, A2.firstname, A2.lastname, A2.passwd, A2.backend, A2.email, A2.phone, A2.phone_ext, A2.mobile, A2.signature, A2.lang, A2.timezone, A2.locale, A2.notes, A2.isactive, A2.isadmin, A2.isvisible, A2.onvacation, A2.assigned_only, A2.show_assigned_tickets, A2.change_passwd, A2.max_page_size, A2.auto_refresh_rate, A2.default_signature_type, A2.default_paper_size, A2.extra, A2.permissions, A2.created, A2.lastlogin, A2.passwdreset, A2.updated FROM ost_team_member A1 JOIN ost_staff A2 ON (A1.staff_id = A2.staff_id) WHERE A1.staff_id = 57"
string(473) "SELECT A1.queue_id, A1.sort_id, A1.bits, A1.sort, A2.id, A2.root, A2.name, A2.columns, A2.updated, A3.id, A3.parent_id, A3.columns_id, A3.sort_id, A3.flags, A3.staff_id, A3.sort, A3.title, A3.config, A3.filter, A3.root, A3.path, A3.created, A3.updated FROM ost_queue_sorts A1 JOIN ost_queue_sort A2 ON (A1.sort_id = A2.id) JOIN ost_queue A3 ON (A1.queue_id = A3.id) WHERE A1.queue_id = 83 ORDER BY A1.sort ASC" string(65) "SELECT COUNT(*) FROM (SELECT A1.id FROM ost_queue_sort A1) __"
string(87) "SELECT A1.* FROM ost_list A1 WHERE A1.type = 'ticket-status' ORDER BY A1.name ASC" string(124) "SELECT A1.* FROM ost_ticket_status A1 WHERE A1.mode & 1 != 0 AND A1.state IN ('open', 'closed') ORDER BY A1.sort ASC"
string(2445) "SELECT A1.number AS number, A1.ticket_id AS ticket_id, A1.created AS created, B6.subject AS cdata__subject, B6.priority AS cdata__priority, MAX(A4.value) AS entries__answers!40__value, A1.isanswered = '0' AS 2GkBZxz, B7.expire > NOW() AND NOT B7.staff_id = 57 AS _locked, B6.priority REGEXP '\"?(?string(108) "SELECT A1.* FROM ost_list_items A1 WHERE A1.list_id = 2 AND A1.status & 1 != 0 ORDER BY A1.value ASC" string(77) "SELECT A1.* FROM ost_ticket_priority A1 ORDER BY A1.priority_urgency DESC" string(85) "SELECT A1.* FROM ost_list_items A1 WHERE A1.list_id = 2 AND A1.id = 158 LIMIT 1" string(71) "SELECT A1.* FROM ost_list A1 WHERE A1.id = 2 ORDER BY A1.name ASC" string(77) "SELECT A1.* FROM ost_form A1 WHERE A1.type = 'L2' ORDER BY A1.title ASC" string(392) "SELECT A1.id, A1.form_id, A1.flags, A1.type, A1.label, A1.name, A1.configuration, A1.sort, A1.hint, A1.created, A1.updated, A2.id, A2.pid, A2.type, A2.flags, A2.title, A2.instructions, A2.name, A2.notes, A2.created, A2.updated FROM ost_form_field A1 LEFT JOIN ost_form A2 ON (A1.form_id = A2.id) WHERE A1.form_id = 14 ORDER BY A1.sort ASC" string(85) "SELECT A1.* FROM ost_list_items A1 WHERE A1.list_id = 2 AND A1.id = 159 LIMIT 1" string(71) "SELECT A1.* FROM ost_list A1 WHERE A1.id = 2 ORDER BY A1.name ASC" string(85) "SELECT A1.* FROM ost_list_items A1 WHERE A1.list_id = 2 AND A1.id = 158 LIMIT 1" string(85) "SELECT A1.* FROM ost_list_items A1 WHERE A1.list_id = 2 AND A1.id = 159 LIMIT 1" string(85) "SELECT A1.* FROM ost_list_items A1 WHERE A1.list_id = 2 AND A1.id = 158 LIMIT 1" string(85) "SELECT A1.* FROM ost_list_items A1 WHERE A1.list_id = 2 AND A1.id = 159 LIMIT 1" string(85) "SELECT A1.* FROM ost_list_items A1 WHERE A1.list_id = 2 AND A1.id = 158 LIMIT 1"
string(10214) "UPDATE ost_session SET session_data = 'csrf|a:2:{s:5:\"token\";s:40:\"7ca54ec603a2a8c831536bde4b334dfe78f16197\";s:4:\"time\";i:1756818686;}staff|a:1:{s:4:\"auth\";a:2:{s:4:\"dest\";s:25:\"/scp/tickets.php?id=13107\";s:3:\"msg\";s:23:\"Authentication Required\";}}auth|a:1:{s:5:\"staff\";a:3:{s:2:\"id\";i:57;s:3:\"key\";s:11:\"local:HansA\";s:3:\"2fa\";N;}}:token|a:1:{s:5:\"staff\";s:76:\"77aebd76fcf8bf71895896247c5a972d:1756818671:1dec8c26a2eb2abbf18d27b6b9739a59\";}TIME_BOMB|i:1756881936;cfg:core|a:1:{s:11:\"db_timezone\";s:3:\"UTC\";}lastcroncall|i:1756818580;:msgs|a:0:{}::Q:T|i:83;sort|a:1:{i:5;a:2:{s:9:\"queuesort\";O:9:\"QueueSort\":7:{s:2:\"ht\";a:5:{s:2:\"id\";i:6;s:4:\"root\";N;s:4:\"name\";s:11:\"Create Date\";s:7:\"columns\";s:12:\"[\"-created\"]\";s:7:\"updated\";s:19:\"2022-11-17 08:55:08\";}s:5:\"dirty\";a:0:{}s:7:\"new\";b:0;s:11:\"deleted\";b:0;s:12:\"deferred\";a:0:{}s:8:\"_columns\";a:1:{s:7:\"created\";b:1;}s:6:\"_extra\";N;}s:3:\"dir\";i:0;}}:form-data|N;:Q:users|O:8:\"QuerySet\":16:{s:5:\"model\";s:4:\"User\";s:11:\"constraints\";a:1:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:2;i:2;a:4:{s:25:\"emailsaddresscontains\";s:5:\"nenad\";s:14:\"namecontains\";s:5:\"nenad\";s:19:\"orgnamecontains\";s:5:\"nenad\";s:22:\"cdataphonecontains\";s:5:\"nenad\";}}}s:16:\"path_constraints\";a:0:{}s:8:\"ordering\";a:1:{i:0;s:4:\"name\";}s:7:\"related\";b:0;s:6:\"values\";a:7:{s:2:\"id\";s:2:\"id\";s:4:\"name\";s:4:\"name\";s:22:\"default_emailaddress\";s:22:\"default_emailaddress\";s:11:\"accountid\";s:11:\"accountid\";s:15:\"accountstatus\";s:15:\"accountstatus\";s:7:\"created\";s:7:\"created\";s:7:\"updated\";s:7:\"updated\";}s:5:\"defer\";a:0:{}s:10:\"aggregated\";b:0;s:11:\"annotations\";a:1:{s:12:\"ticket_count\";O:12:\"SqlAggregate\":5:{s:5:\"alias\";s:12:\"ticket_count\";s:4:\"func\";s:5:\"COUNT\";s:4:\"expr\";s:7:\"tickets\";s:8:\"distinct\";b:0;s:10:\"constraint\";b:0;}}s:5:\"extra\";a:0:{}s:8:\"distinct\";a:0:{}s:4:\"lock\";b:0;s:5:\"chain\";a:0:{}s:7:\"options\";a:0:{}s:4:\"iter\";i:2;s:8:\"compiler\";s:13:\"MySqlCompiler\";}:U:tickets|O:8:\"QuerySet\":16:{s:5:\"model\";s:6:\"Ticket\";s:11:\"constraints\";a:2:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{s:13:\"ticket_idin\";O:8:\"QuerySet\":16:{s:5:\"model\";s:6:\"Ticket\";s:11:\"constraints\";a:1:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{s:7:\"user_id\";i:5264;}}}s:16:\"path_constraints\";a:0:{}s:8:\"ordering\";a:0:{}s:7:\"related\";b:0;s:6:\"values\";a:1:{i:0;s:9:\"ticket_id\";}s:5:\"defer\";a:0:{}s:10:\"aggregated\";b:0;s:11:\"annotations\";a:0:{}s:5:\"extra\";a:0:{}s:8:\"distinct\";a:0:{}s:4:\"lock\";b:0;s:5:\"chain\";a:1:{i:0;a:2:{i:0;O:8:\"QuerySet\":16:{s:5:\"model\";s:6:\"Ticket\";s:11:\"constraints\";a:1:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{s:30:\"threadcollaboratorsuser_id\";i:5264;}}}s:16:\"path_constraints\";a:0:{}s:8:\"ordering\";a:0:{}s:7:\"related\";b:0;s:6:\"values\";a:1:{i:0;s:9:\"ticket_id\";}s:5:\"defer\";a:0:{}s:10:\"aggregated\";b:0;s:11:\"annotations\";a:0:{}s:5:\"extra\";a:0:{}s:8:\"distinct\";a:0:{}s:4:\"lock\";b:0;s:5:\"chain\";a:0:{}s:7:\"options\";a:0:{}s:4:\"iter\";i:3;s:8:\"compiler\";s:13:\"MySqlCompiler\";}i:1;b:0;}}s:7:\"options\";a:0:{}s:4:\"iter\";i:3;s:8:\"compiler\";s:13:\"MySqlCompiler\";}}}i:1;O:1:\"Q\":3:{i:0;i:0;i:1;i:2;i:2;a:3:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:2:{s:13:\"statusstate\";s:4:\"open\";i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:2;i:2;a:6:{s:8:\"staff_id\";i:57;s:34:\"threadreferralsagentstaff_id\";i:57;i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:2:{s:25:\"child_threadobject_type\";s:1:\"C\";s:40:\"child_threadreferralsagentstaff_id\";i:57;}}}}s:11:\"team_idin\";a:2:{i:0;i:8;i:1;i:9;}s:36:\"threadreferralsteamteam_idin\";a:2:{i:0;i:8;i:1;i:9;}i:1;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:2:{s:25:\"child_threadobject_type\";s:1:\"C\";s:42:\"child_threadreferralsteamteam_idin\";a:2:{i:0;i:8;i:1;i:9;}}}}}}}}}i:1;O:1:\"Q\":3:{i:0;i:0;i:1;i:2;i:2;a:2:{s:11:\"dept_idin\";a:3:{i:0;i:1;i:1;i:5;i:2;i:9;}s:31:\"threadreferralsdeptidin\";a:3:{i:0;i:1;i:1;i:5;i:2;i:9;}}}i:2;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:2:{s:25:\"child_threadobject_type\";s:1:\"C\";s:37:\"child_threadreferralsdeptidin\";a:3:{i:0;i:1;i:1;i:5;i:2;i:9;}}}}}}}}s:16:\"path_constraints\";a:1:{s:4:\"lock\";a:1:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{s:16:\"lockexpiregt\";O:11:\"SqlFunction\":3:{s:5:\"alias\";N;s:4:\"func\";s:3:\"NOW\";s:4:\"args\";a:0:{}}}}}}s:8:\"ordering\";a:1:{i:0;s:8:\"-created\";}s:7:\"related\";b:0;s:6:\"values\";a:21:{s:8:\"staff_id\";s:8:\"staff_id\";s:16:\"stafffirstname\";s:16:\"stafffirstname\";s:15:\"stafflastname\";s:15:\"stafflastname\";s:10:\"teamname\";s:10:\"teamname\";s:7:\"team_id\";s:7:\"team_id\";s:13:\"locklock_id\";s:13:\"locklock_id\";s:14:\"lockstaff_id\";s:14:\"lockstaff_id\";s:9:\"isoverdue\";s:9:\"isoverdue\";s:9:\"status_id\";s:9:\"status_id\";s:12:\"statusname\";s:12:\"statusname\";s:13:\"statusstate\";s:13:\"statusstate\";s:6:\"number\";s:6:\"number\";s:14:\"cdatasubject\";s:14:\"cdatasubject\";s:9:\"ticket_id\";s:9:\"ticket_id\";s:6:\"source\";s:6:\"source\";s:7:\"dept_id\";s:7:\"dept_id\";s:10:\"deptname\";s:10:\"deptname\";s:7:\"user_id\";s:7:\"user_id\";s:28:\"userdefault_emailaddress\";s:28:\"userdefault_emailaddress\";s:10:\"username\";s:10:\"username\";s:10:\"lastupdate\";s:10:\"lastupdate\";}s:5:\"defer\";a:0:{}s:10:\"aggregated\";b:0;s:11:\"annotations\";a:3:{s:12:\"collab_count\";O:12:\"SqlAggregate\":5:{s:5:\"alias\";s:12:\"collab_count\";s:4:\"func\";s:5:\"COUNT\";s:4:\"expr\";s:21:\"threadcollaborators\";s:8:\"distinct\";b:1;s:10:\"constraint\";b:0;}s:16:\"attachment_count\";O:12:\"SqlAggregate\":5:{s:5:\"alias\";s:16:\"attachment_count\";s:4:\"func\";s:5:\"COUNT\";s:4:\"expr\";O:7:\"SqlCase\":5:{s:5:\"alias\";N;s:5:\"cases\";a:1:{i:0;a:2:{i:0;O:8:\"SqlField\":5:{s:5:\"alias\";N;s:8:\"operator\";N;s:8:\"operands\";N;s:5:\"level\";i:0;s:5:\"field\";s:36:\"threadentriesattachmentsinline\";}i:1;N;}}s:4:\"else\";O:8:\"SqlField\":5:{s:5:\"alias\";N;s:8:\"operator\";N;s:8:\"operands\";N;s:5:\"level\";i:0;s:5:\"field\";s:28:\"threadentriesattachments\";}s:4:\"func\";s:4:\"CASE\";s:4:\"args\";a:0:{}}s:8:\"distinct\";b:1;s:10:\"constraint\";b:0;}s:12:\"thread_count\";O:12:\"SqlAggregate\":5:{s:5:\"alias\";s:12:\"thread_count\";s:4:\"func\";s:5:\"COUNT\";s:4:\"expr\";O:7:\"SqlCase\":5:{s:5:\"alias\";N;s:5:\"cases\";a:1:{i:0;a:2:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{s:30:\"threadentriesflagshasbit\";i:4;}}i:1;N;}}s:4:\"else\";O:8:\"SqlField\":5:{s:5:\"alias\";N;s:8:\"operator\";N;s:8:\"operands\";N;s:5:\"level\";i:0;s:5:\"field\";s:19:\"threadentriesid\";}s:4:\"func\";s:4:\"CASE\";s:4:\"args\";a:0:{}}s:8:\"distinct\";b:1;s:10:\"constraint\";b:0;}}s:5:\"extra\";a:0:{}s:8:\"distinct\";a:1:{i:0;s:9:\"ticket_id\";}s:4:\"lock\";b:0;s:5:\"chain\";a:0:{}s:7:\"options\";a:0:{}s:4:\"iter\";i:2;s:8:\"compiler\";s:13:\"MySqlCompiler\";}::Q:A|s:0:\"\";:QA::sort|a:2:{i:0;s:7:\"created\";i:1;i:0;}:Q:tasks|O:8:\"QuerySet\":16:{s:5:\"model\";s:4:\"Task\";s:11:\"constraints\";a:2:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{s:13:\"flagshasbit\";i:1;}}}}i:1;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:2;i:2;a:4:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:2:{s:13:\"flagshasbit\";i:1;s:8:\"staff_id\";i:57;}}i:1;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:2:{s:16:\"ticketstaff_id\";i:57;s:21:\"ticketstatusstate\";s:4:\"open\";}}i:2;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{s:11:\"dept_idin\";a:3:{i:0;i:1;i:1;i:5;i:2;i:9;}}}i:3;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:2:{s:11:\"team_idin\";a:2:{i:0;i:8;i:1;i:9;}s:13:\"flagshasbit\";i:1;}}}}}}}s:16:\"path_constraints\";a:0:{}s:8:\"ordering\";a:1:{i:0;s:8:\"-created\";}s:7:\"related\";b:0;s:6:\"values\";a:13:{s:2:\"id\";s:2:\"id\";s:6:\"number\";s:6:\"number\";s:7:\"created\";s:7:\"created\";s:8:\"staff_id\";s:8:\"staff_id\";s:7:\"team_id\";s:7:\"team_id\";s:16:\"stafffirstname\";s:16:\"stafffirstname\";s:15:\"stafflastname\";s:15:\"stafflastname\";s:10:\"teamname\";s:10:\"teamname\";s:10:\"deptname\";s:10:\"deptname\";s:12:\"cdatatitle\";s:12:\"cdatatitle\";s:5:\"flags\";s:5:\"flags\";s:14:\"ticketnumber\";s:14:\"ticketnumber\";s:17:\"ticketticket_id\";s:17:\"ticketticket_id\";}s:5:\"defer\";a:0:{}s:10:\"aggregated\";b:0;s:11:\"annotations\";a:3:{s:12:\"collab_count\";O:12:\"SqlAggregate\":5:{s:5:\"alias\";s:12:\"collab_count\";s:4:\"func\";s:5:\"COUNT\";s:4:\"expr\";s:21:\"threadcollaborators\";s:8:\"distinct\";b:1;s:10:\"constraint\";b:0;}s:16:\"attachment_count\";O:12:\"SqlAggregate\":5:{s:5:\"alias\";s:16:\"attachment_count\";s:4:\"func\";s:5:\"COUNT\";s:4:\"expr\";O:7:\"SqlCase\":5:{s:5:\"alias\";N;s:5:\"cases\";a:1:{i:0;a:2:{i:0;O:8:\"SqlField\":5:{s:5:\"alias\";N;s:8:\"operator\";N;s:8:\"operands\";N;s:5:\"level\";i:0;s:5:\"field\";s:36:\"threadentriesattachmentsinline\";}i:1;N;}}s:4:\"else\";O:8:\"SqlField\":5:{s:5:\"alias\";N;s:8:\"operator\";N;s:8:\"operands\";N;s:5:\"level\";i:0;s:5:\"field\";s:28:\"threadentriesattachments\";}s:4:\"func\";s:4:\"CASE\";s:4:\"args\";a:0:{}}s:8:\"distinct\";b:1;s:10:\"constraint\";b:0;}s:12:\"thread_count\";O:12:\"SqlAggregate\":5:{s:5:\"alias\";s:12:\"thread_count\";s:4:\"func\";s:5:\"COUNT\";s:4:\"expr\";O:7:\"SqlCase\":5:{s:5:\"alias\";N;s:5:\"cases\";a:1:{i:0;a:2:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{s:30:\"threadentriesflagshasbit\";i:4;}}i:1;N;}}s:4:\"else\";O:8:\"SqlField\":5:{s:5:\"alias\";N;s:8:\"operator\";N;s:8:\"operands\";N;s:5:\"level\";i:0;s:5:\"field\";s:19:\"threadentriesid\";}s:4:\"func\";s:4:\"CASE\";s:4:\"args\";a:0:{}}s:8:\"distinct\";b:1;s:10:\"constraint\";b:0;}}s:5:\"extra\";a:0:{}s:8:\"distinct\";a:0:{}s:4:\"lock\";b:0;s:5:\"chain\";a:0:{}s:7:\"options\";a:0:{}s:4:\"iter\";i:2;s:8:\"compiler\";s:13:\"MySqlCompiler\";}', session_updated = NOW() WHERE ost_session.session_id = 'o1neu0kdhej58ucf0eq6n4k37g' LIMIT 1" string(45) "SELECT A1.id, A1.name FROM ost_event A1"
Copyright © 2006-2025 string(142) "SELECT COLUMN_NAME FROM INFORMATION_SCHEMA.COLUMNS WHERE TABLE_NAME = 'ost_form_entry' AND TABLE_SCHEMA = DATABASE() ORDER BY ORDINAL_POSITION" string(366) "SELECT A1.id, A1.form_id, A1.object_id, A1.object_type, A1.sort, A1.extra, A1.created, A1.updated, A2.id, A2.pid, A2.type, A2.flags, A2.title, A2.instructions, A2.name, A2.notes, A2.created, A2.updated FROM ost_form_entry A1 LEFT JOIN ost_form A2 ON (A1.form_id = A2.id) WHERE A1.object_type = 'C' ORDER BY A1.sort ASC" string(334) "SELECT A1.entry_id, A1.field_id, A1.value, A1.value_id, A2.id, A2.form_id, A2.flags, A2.type, A2.label, A2.name, A2.configuration, A2.sort, A2.hint, A2.created, A2.updated FROM ost_form_entry_values A1 JOIN ost_form_field A2 ON (A1.field_id = A2.id) WHERE A1.entry_id = 2 ORDER BY A2.sort ASC" Newland EMEA BV All Rights Reserved.
string(10214) "UPDATE ost_session SET session_data = 'csrf|a:2:{s:5:\"token\";s:40:\"7ca54ec603a2a8c831536bde4b334dfe78f16197\";s:4:\"time\";i:1756818580;}staff|a:1:{s:4:\"auth\";a:2:{s:4:\"dest\";s:25:\"/scp/tickets.php?id=13107\";s:3:\"msg\";s:23:\"Authentication Required\";}}auth|a:1:{s:5:\"staff\";a:3:{s:2:\"id\";i:57;s:3:\"key\";s:11:\"local:HansA\";s:3:\"2fa\";N;}}:token|a:1:{s:5:\"staff\";s:76:\"c59778870b4ad17787e24795ca30545e:1756818578:1dec8c26a2eb2abbf18d27b6b9739a59\";}TIME_BOMB|i:1756881936;cfg:core|a:1:{s:11:\"db_timezone\";s:3:\"UTC\";}lastcroncall|i:1756818034;:msgs|a:0:{}::Q:T|i:83;sort|a:1:{i:5;a:2:{s:9:\"queuesort\";O:9:\"QueueSort\":7:{s:2:\"ht\";a:5:{s:2:\"id\";i:6;s:4:\"root\";N;s:4:\"name\";s:11:\"Create Date\";s:7:\"columns\";s:12:\"[\"-created\"]\";s:7:\"updated\";s:19:\"2022-11-17 08:55:08\";}s:5:\"dirty\";a:0:{}s:7:\"new\";b:0;s:11:\"deleted\";b:0;s:12:\"deferred\";a:0:{}s:8:\"_columns\";a:1:{s:7:\"created\";b:1;}s:6:\"_extra\";N;}s:3:\"dir\";i:0;}}:form-data|N;:Q:users|O:8:\"QuerySet\":16:{s:5:\"model\";s:4:\"User\";s:11:\"constraints\";a:1:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:2;i:2;a:4:{s:25:\"emailsaddresscontains\";s:5:\"nenad\";s:14:\"namecontains\";s:5:\"nenad\";s:19:\"orgnamecontains\";s:5:\"nenad\";s:22:\"cdataphonecontains\";s:5:\"nenad\";}}}s:16:\"path_constraints\";a:0:{}s:8:\"ordering\";a:1:{i:0;s:4:\"name\";}s:7:\"related\";b:0;s:6:\"values\";a:7:{s:2:\"id\";s:2:\"id\";s:4:\"name\";s:4:\"name\";s:22:\"default_emailaddress\";s:22:\"default_emailaddress\";s:11:\"accountid\";s:11:\"accountid\";s:15:\"accountstatus\";s:15:\"accountstatus\";s:7:\"created\";s:7:\"created\";s:7:\"updated\";s:7:\"updated\";}s:5:\"defer\";a:0:{}s:10:\"aggregated\";b:0;s:11:\"annotations\";a:1:{s:12:\"ticket_count\";O:12:\"SqlAggregate\":5:{s:5:\"alias\";s:12:\"ticket_count\";s:4:\"func\";s:5:\"COUNT\";s:4:\"expr\";s:7:\"tickets\";s:8:\"distinct\";b:0;s:10:\"constraint\";b:0;}}s:5:\"extra\";a:0:{}s:8:\"distinct\";a:0:{}s:4:\"lock\";b:0;s:5:\"chain\";a:0:{}s:7:\"options\";a:0:{}s:4:\"iter\";i:2;s:8:\"compiler\";s:13:\"MySqlCompiler\";}:U:tickets|O:8:\"QuerySet\":16:{s:5:\"model\";s:6:\"Ticket\";s:11:\"constraints\";a:2:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{s:13:\"ticket_idin\";O:8:\"QuerySet\":16:{s:5:\"model\";s:6:\"Ticket\";s:11:\"constraints\";a:1:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{s:7:\"user_id\";i:5264;}}}s:16:\"path_constraints\";a:0:{}s:8:\"ordering\";a:0:{}s:7:\"related\";b:0;s:6:\"values\";a:1:{i:0;s:9:\"ticket_id\";}s:5:\"defer\";a:0:{}s:10:\"aggregated\";b:0;s:11:\"annotations\";a:0:{}s:5:\"extra\";a:0:{}s:8:\"distinct\";a:0:{}s:4:\"lock\";b:0;s:5:\"chain\";a:1:{i:0;a:2:{i:0;O:8:\"QuerySet\":16:{s:5:\"model\";s:6:\"Ticket\";s:11:\"constraints\";a:1:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{s:30:\"threadcollaboratorsuser_id\";i:5264;}}}s:16:\"path_constraints\";a:0:{}s:8:\"ordering\";a:0:{}s:7:\"related\";b:0;s:6:\"values\";a:1:{i:0;s:9:\"ticket_id\";}s:5:\"defer\";a:0:{}s:10:\"aggregated\";b:0;s:11:\"annotations\";a:0:{}s:5:\"extra\";a:0:{}s:8:\"distinct\";a:0:{}s:4:\"lock\";b:0;s:5:\"chain\";a:0:{}s:7:\"options\";a:0:{}s:4:\"iter\";i:3;s:8:\"compiler\";s:13:\"MySqlCompiler\";}i:1;b:0;}}s:7:\"options\";a:0:{}s:4:\"iter\";i:3;s:8:\"compiler\";s:13:\"MySqlCompiler\";}}}i:1;O:1:\"Q\":3:{i:0;i:0;i:1;i:2;i:2;a:3:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:2:{s:13:\"statusstate\";s:4:\"open\";i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:2;i:2;a:6:{s:8:\"staff_id\";i:57;s:34:\"threadreferralsagentstaff_id\";i:57;i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:2:{s:25:\"child_threadobject_type\";s:1:\"C\";s:40:\"child_threadreferralsagentstaff_id\";i:57;}}}}s:11:\"team_idin\";a:2:{i:0;i:8;i:1;i:9;}s:36:\"threadreferralsteamteam_idin\";a:2:{i:0;i:8;i:1;i:9;}i:1;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:2:{s:25:\"child_threadobject_type\";s:1:\"C\";s:42:\"child_threadreferralsteamteam_idin\";a:2:{i:0;i:8;i:1;i:9;}}}}}}}}}i:1;O:1:\"Q\":3:{i:0;i:0;i:1;i:2;i:2;a:2:{s:11:\"dept_idin\";a:3:{i:0;i:1;i:1;i:5;i:2;i:9;}s:31:\"threadreferralsdeptidin\";a:3:{i:0;i:1;i:1;i:5;i:2;i:9;}}}i:2;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:2:{s:25:\"child_threadobject_type\";s:1:\"C\";s:37:\"child_threadreferralsdeptidin\";a:3:{i:0;i:1;i:1;i:5;i:2;i:9;}}}}}}}}s:16:\"path_constraints\";a:1:{s:4:\"lock\";a:1:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{s:16:\"lockexpiregt\";O:11:\"SqlFunction\":3:{s:5:\"alias\";N;s:4:\"func\";s:3:\"NOW\";s:4:\"args\";a:0:{}}}}}}s:8:\"ordering\";a:1:{i:0;s:8:\"-created\";}s:7:\"related\";b:0;s:6:\"values\";a:21:{s:8:\"staff_id\";s:8:\"staff_id\";s:16:\"stafffirstname\";s:16:\"stafffirstname\";s:15:\"stafflastname\";s:15:\"stafflastname\";s:10:\"teamname\";s:10:\"teamname\";s:7:\"team_id\";s:7:\"team_id\";s:13:\"locklock_id\";s:13:\"locklock_id\";s:14:\"lockstaff_id\";s:14:\"lockstaff_id\";s:9:\"isoverdue\";s:9:\"isoverdue\";s:9:\"status_id\";s:9:\"status_id\";s:12:\"statusname\";s:12:\"statusname\";s:13:\"statusstate\";s:13:\"statusstate\";s:6:\"number\";s:6:\"number\";s:14:\"cdatasubject\";s:14:\"cdatasubject\";s:9:\"ticket_id\";s:9:\"ticket_id\";s:6:\"source\";s:6:\"source\";s:7:\"dept_id\";s:7:\"dept_id\";s:10:\"deptname\";s:10:\"deptname\";s:7:\"user_id\";s:7:\"user_id\";s:28:\"userdefault_emailaddress\";s:28:\"userdefault_emailaddress\";s:10:\"username\";s:10:\"username\";s:10:\"lastupdate\";s:10:\"lastupdate\";}s:5:\"defer\";a:0:{}s:10:\"aggregated\";b:0;s:11:\"annotations\";a:3:{s:12:\"collab_count\";O:12:\"SqlAggregate\":5:{s:5:\"alias\";s:12:\"collab_count\";s:4:\"func\";s:5:\"COUNT\";s:4:\"expr\";s:21:\"threadcollaborators\";s:8:\"distinct\";b:1;s:10:\"constraint\";b:0;}s:16:\"attachment_count\";O:12:\"SqlAggregate\":5:{s:5:\"alias\";s:16:\"attachment_count\";s:4:\"func\";s:5:\"COUNT\";s:4:\"expr\";O:7:\"SqlCase\":5:{s:5:\"alias\";N;s:5:\"cases\";a:1:{i:0;a:2:{i:0;O:8:\"SqlField\":5:{s:5:\"alias\";N;s:8:\"operator\";N;s:8:\"operands\";N;s:5:\"level\";i:0;s:5:\"field\";s:36:\"threadentriesattachmentsinline\";}i:1;N;}}s:4:\"else\";O:8:\"SqlField\":5:{s:5:\"alias\";N;s:8:\"operator\";N;s:8:\"operands\";N;s:5:\"level\";i:0;s:5:\"field\";s:28:\"threadentriesattachments\";}s:4:\"func\";s:4:\"CASE\";s:4:\"args\";a:0:{}}s:8:\"distinct\";b:1;s:10:\"constraint\";b:0;}s:12:\"thread_count\";O:12:\"SqlAggregate\":5:{s:5:\"alias\";s:12:\"thread_count\";s:4:\"func\";s:5:\"COUNT\";s:4:\"expr\";O:7:\"SqlCase\":5:{s:5:\"alias\";N;s:5:\"cases\";a:1:{i:0;a:2:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{s:30:\"threadentriesflagshasbit\";i:4;}}i:1;N;}}s:4:\"else\";O:8:\"SqlField\":5:{s:5:\"alias\";N;s:8:\"operator\";N;s:8:\"operands\";N;s:5:\"level\";i:0;s:5:\"field\";s:19:\"threadentriesid\";}s:4:\"func\";s:4:\"CASE\";s:4:\"args\";a:0:{}}s:8:\"distinct\";b:1;s:10:\"constraint\";b:0;}}s:5:\"extra\";a:0:{}s:8:\"distinct\";a:1:{i:0;s:9:\"ticket_id\";}s:4:\"lock\";b:0;s:5:\"chain\";a:0:{}s:7:\"options\";a:0:{}s:4:\"iter\";i:2;s:8:\"compiler\";s:13:\"MySqlCompiler\";}::Q:A|s:0:\"\";:QA::sort|a:2:{i:0;s:7:\"created\";i:1;i:0;}:Q:tasks|O:8:\"QuerySet\":16:{s:5:\"model\";s:4:\"Task\";s:11:\"constraints\";a:2:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{s:13:\"flagshasbit\";i:1;}}}}i:1;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:2;i:2;a:4:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:2:{s:13:\"flagshasbit\";i:1;s:8:\"staff_id\";i:57;}}i:1;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:2:{s:16:\"ticketstaff_id\";i:57;s:21:\"ticketstatusstate\";s:4:\"open\";}}i:2;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{s:11:\"dept_idin\";a:3:{i:0;i:1;i:1;i:5;i:2;i:9;}}}i:3;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:2:{s:11:\"team_idin\";a:2:{i:0;i:8;i:1;i:9;}s:13:\"flagshasbit\";i:1;}}}}}}}s:16:\"path_constraints\";a:0:{}s:8:\"ordering\";a:1:{i:0;s:8:\"-created\";}s:7:\"related\";b:0;s:6:\"values\";a:13:{s:2:\"id\";s:2:\"id\";s:6:\"number\";s:6:\"number\";s:7:\"created\";s:7:\"created\";s:8:\"staff_id\";s:8:\"staff_id\";s:7:\"team_id\";s:7:\"team_id\";s:16:\"stafffirstname\";s:16:\"stafffirstname\";s:15:\"stafflastname\";s:15:\"stafflastname\";s:10:\"teamname\";s:10:\"teamname\";s:10:\"deptname\";s:10:\"deptname\";s:12:\"cdatatitle\";s:12:\"cdatatitle\";s:5:\"flags\";s:5:\"flags\";s:14:\"ticketnumber\";s:14:\"ticketnumber\";s:17:\"ticketticket_id\";s:17:\"ticketticket_id\";}s:5:\"defer\";a:0:{}s:10:\"aggregated\";b:0;s:11:\"annotations\";a:3:{s:12:\"collab_count\";O:12:\"SqlAggregate\":5:{s:5:\"alias\";s:12:\"collab_count\";s:4:\"func\";s:5:\"COUNT\";s:4:\"expr\";s:21:\"threadcollaborators\";s:8:\"distinct\";b:1;s:10:\"constraint\";b:0;}s:16:\"attachment_count\";O:12:\"SqlAggregate\":5:{s:5:\"alias\";s:16:\"attachment_count\";s:4:\"func\";s:5:\"COUNT\";s:4:\"expr\";O:7:\"SqlCase\":5:{s:5:\"alias\";N;s:5:\"cases\";a:1:{i:0;a:2:{i:0;O:8:\"SqlField\":5:{s:5:\"alias\";N;s:8:\"operator\";N;s:8:\"operands\";N;s:5:\"level\";i:0;s:5:\"field\";s:36:\"threadentriesattachmentsinline\";}i:1;N;}}s:4:\"else\";O:8:\"SqlField\":5:{s:5:\"alias\";N;s:8:\"operator\";N;s:8:\"operands\";N;s:5:\"level\";i:0;s:5:\"field\";s:28:\"threadentriesattachments\";}s:4:\"func\";s:4:\"CASE\";s:4:\"args\";a:0:{}}s:8:\"distinct\";b:1;s:10:\"constraint\";b:0;}s:12:\"thread_count\";O:12:\"SqlAggregate\":5:{s:5:\"alias\";s:12:\"thread_count\";s:4:\"func\";s:5:\"COUNT\";s:4:\"expr\";O:7:\"SqlCase\":5:{s:5:\"alias\";N;s:5:\"cases\";a:1:{i:0;a:2:{i:0;O:1:\"Q\":3:{i:0;i:0;i:1;i:0;i:2;a:1:{s:30:\"threadentriesflagshasbit\";i:4;}}i:1;N;}}s:4:\"else\";O:8:\"SqlField\":5:{s:5:\"alias\";N;s:8:\"operator\";N;s:8:\"operands\";N;s:5:\"level\";i:0;s:5:\"field\";s:19:\"threadentriesid\";}s:4:\"func\";s:4:\"CASE\";s:4:\"args\";a:0:{}}s:8:\"distinct\";b:1;s:10:\"constraint\";b:0;}}s:5:\"extra\";a:0:{}s:8:\"distinct\";a:0:{}s:4:\"lock\";b:0;s:5:\"chain\";a:0:{}s:7:\"options\";a:0:{}s:4:\"iter\";i:2;s:8:\"compiler\";s:13:\"MySqlCompiler\";}', session_updated = NOW() WHERE ost_session.session_id = 'o1neu0kdhej58ucf0eq6n4k37g' LIMIT 1" string(45) "SELECT A1.id, A1.name FROM ost_event A1"
