Hi, a 1.10.4 system was set up by someone who left without documentation. I am an Admin on the system but when I upload an upgrade according to the documentation, the automatic setup doesn't start which suggests that I don't have rights to do this. I can see a user in the database with the first name of the person who set it up, and I would imagine that this account has the admin role. How can I take control of this system? Should I install a new system and import the data? This is not preferable really, but it would get me control. I did find a user called OSTICKETADMIN in ost_staff and have managed to log in as that, but the upgrade does not begin. PHP is 7.2. Mysql is 5.5.
Do you have access to where the instance of OSTicket is installed? If so, the you would have more options.
    timgowen
    If you replaced your old files with the latest version then you must then login and click Upgrade button when the Upgrade Wizard appears. If you login and don't see an Upgrade Wizard then you didn't do something right.
