I did apply this and it does not work. I uploaded a large .run file and it works but then I tried to upload a small .RUN file but then it fails to download so I assume it never made its way to permanent location and I get an email notification every time.
(root)/st0rag3/M/MhEFeiqA1LeoNvprVXbX5_nTw09LS3t8: Unable to read from file
#0 (root)/include/class.file.php(123): FilesystemStorage->passthru()
#1 (root)/include/class.file.php(283): AttachmentFile->sendData(false)
#2 (root)/file.php(68): AttachmentFile->download(NULL, 'attachment', '1650931200')
#3 {main}
BUT there is a difference
- large .RUN can be downloaded, it thinks for a bit then the file comes up for saving onto disk
- small .RUN cannot be downloaded, ends up "This site can’t be reached" in Chrome and an email notification each time I try to download it (example above)
- large .DEB comes up immediately for saving but the file is 0 kB, no email notification
I have the output of php -i if it can shed any light but not sure what extension to use as it does not accept .txt as attachment in here
